Six Speed Speedo Wiring?
Sean, the drawing shows a pin #9 on the Blue Frequency converter module. However, there is no #9 pin, but a #6 pin on the module. Could you confirm?
Based on a old document I have, it shows that #7 is GND and #2 is Power. Does this match your findings.
I lost the frequency module about 5 years ago, just found it with the instructions. Just in time to install.
i have modified the diagram to show power and earth
Power is pin 2
Earth is pin 7
I like the six speed box for my car. You still have 60mph in second and the ratios are fine. The 968TS cars had a taller 5th and 6th gear, which are available. Garrity installed my 89 951 trans cooler to the six speed. The six speed is a stronger unit. I'm also going to install a 968 bell housing to allow for 4 hour clutch jobs.
Should have just built a 968TS............
I like the six speed for my car. One of the fastest 951's at PIR for years had a six speed with an original 3.0 Turbo S motor in his 86 951 race car.
Here is a 968 transmission diagram link for those interested. My tire size give the car about a 180mph top speed. The five speed is taller, but you can get gears for the six speed to cure top speed issues.
http://www.studiodual.com/968/transmission_diagram.gif
George
Seems like there are many opinions, but few actual six speed boxes in high powered 951's.
George
George
I just had a 5 speed lsd done by Kevin G, but have not installed it yet. I considered getting a 6 speed but was hoping for more brave pioneers to try it first and report in -- so your reactions are very appreciated. Planning to do the TT at the same time. In the meantime, can you tell me more about the 4 hour clutch jobs?
The 968's have a "window" of sorts on the bellhousing which enables clutch assy removal without removing the whole back half of the car.
It's awesome, and a wonder Porsche didn't think of it sooner...
I like the 6-spd on the 951. I switched from the 951S transaxle to the 6-spd, I loved it. I had a short shift kit on the 5-spd, which made it very nice to shoft. I'm yet to find a short shifter for the 6-spf. The 6-spd seems a bit sloppy to shift. Did anyone else experience this?
I initially had the torsen LSD on the 6-spd. I did not like the way the rear end squirmed under braking. I switched to a Porsche Motorsports clutch based LSD, but haven't tried it yet.
I actually find the 6-spd a lot better to shift than the 5, it was all upgrade for me.. I got the relay at a wrecker, even in Australia it was not expensive, and common, The ABS unit I sourced in the US
I wonder how different the 6 speed is to the 5 speed with the S2 r&p? Obviously the 6 speed will have a higher top speed but up to that point I am curious how this would differ.
I also find the 6 speed very precise when shifting, it almost feels like I'm shifting a gated transmission. Oner thing I did notice is that the stock shifter with shift rod has a great deal of shifter travel from reverse to 6th, I installed a billet shifter with Momo **** to fix this. Has any one heard of a short shift (transmission end) for a 6 speed?
By the way, I love this transmission so much, it really transformed my car.
