Mobil oil co. recommends 0w40 for our cars
#31
Wasn't the owner's manual written in the early 1980s? Porsche changed their recommendations based on the performance of their products and changes to the make up of the oil.
I thought the oil leakage with synthetic was an old wise tale. I moved from non-synthetic to synthenic in my 1987 924S without issue. As far as I know, everything was original. It did not leak a drop of oil.
no leaks, from what i've heard you're the exception, let's wait and see if anyone else chimes in with no leakage.
how long ago did you move to synthetic, how many miles were on the car?
seattle doesn't get real hot or cold so 0-40 works well.
i doubt very seriously if many, if any 944/951's, are running 0-40 in phx, az, last weekend it hit 114.
i used 20-50 valvoline synpower in hawaii because the po had rebuilt the eng and recommended continued use, same diet in phoenix.
87951
95sl320 dd
#32
yeah i think the manuals were in the cars when delivered.
87951
95sl320 dd
87951
95sl320 dd
I probably put 50,000 mile on it over 4 years. The mileadge was either 80,000 or 180,000. I changed to synthetics about 3 months after purchasing it. It ran for 4 to 5 years without a leak up until the point where I sold it.
#33
Its good information for people that newly rebuilt engines but 75% of us have for the most part factory engines. so the tolerances have maybe worn a little. i was told 20w 50 But of course i live in TN (as of right now) and it freezes maybe 10 days a year. I would still be very hesitant with 0w40
Pumping a thick oil requires more energy than pumping a thin oil. The energy differential is retained as heat increasing the oil temperature and engine heat.
If a thicker oil flows a lower volume through an oil cooler, the oil cooler is less effiecient resulting in more heat being kept in the engine. (Bad thing)
Wouldn't it make sense to run the lightest weight oil possible that meets requirements for film stregnth and lubrication? You would only want to move to the thicker oils once heat levels have exceeded the thin oil's ability to provide desired film stregnth and lubrication.
As oil technology improves, new thin oils will be able provide heat performance that is superior to the previous generation of thick oils. As time goes on, you may want to move to thinner and thinner oils to take advantage of technology breakthroughs.
Of course, if worn engine components and tolerances is driving the decision, this point is mute.
#34
"Wouldn't it make sense to run the lightest weight oil possible that meets requirements for film stregnth and lubrication? You would only want to move to the thicker oils once heat levels have exceeded the thin oil's ability to provide desired film stregnth and lubrication."
you've answered your own question of why folks run 20-50 in a hot climate even though it's contrary to porsche's newer recommendations.
87951
95sl320 dd
87951
95sl320 dd
#35
Putting the tolerance issue aside, would running a lighter weight oil help with cooling and thus could be better in hot climate?
Sure, you can run thinner oils but the car was built to run thicker oils and as a result its oil passages/lifters/etc are made to run thicker oil. As you mentioned thinner oil will drop resistance and less force will be needed to move the oil though the system. This means your getting less pressure throughout under the same conditions. You do have a OPRV but eventually when your oil gets so thin it simply will not have the required pressure.
#36
for a street car that isnt running high rpms all the time it wont make much of a difference. Unless your running close to oil chemically breaking down temps it shouldnt matter. Lower weight has been proven to show lower oil pressure in hot climates on older engines. Ive read of a couple cases where they switched to a heavier weight and it restored adequate pressure at idle rpms. Cooler oil is nice but if its not getting through the engine then thats a bigger problem
EDIT: Fishy beat me to it LOL
#37
Rainman
87951
95sl320 dd
87951
95sl320 dd
#38
87951
95sl320 dd
87951
95sl320 dd
My understanding is that the 951 does not get hot enough during street driving anywhere in the United States in the summer to exceed the capabilities of modern 0W-40 synthetic. This was a contributing factor to Porsche's new recommendation for this weight oil for cars in the U.S.
#39
There is a thing called oil pressure you might want to consult with it.. lol!
#40
Here you go. Sit down and read all about it. Might want to make a sandwich first though....
http://forums.pelicanparts.com/showthread.php?t=367300
#42
We use 25w/60 for the track.
#43
#44
My assumption is "no" or Porsche would not be recommending this oil for the 951 in the United States.
