block refinishing....interested?
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I am thinking about adding another engine rebuilding solution, what do you guys think?
I have been doing the MID sleeved engines for quite a while, dry sleeves before that in addition to stock bore rebuilds.
For about a year and a half I have had a test engine out there running alusil compatible pistons (about 50 track days) so now I am completely comfortable with the ability of the custom pistons / rings to run in the alusil bores.
So the next logical step is to offer an overbore ‘kit’ for those the like to build their own engines. 100.5 or 101 mm bore (using your core block) with new pistons and rings for $1500…any thoughts?
BTW – we can spec any compression ratio you want.
The issue is finding someone competent in your area to do the overbore on your cylinders. Most shops are used to doing iron blocks not the alusil. I am in the process of trying to locate someone in my area, if not then you have to crate it up and send else where.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Boring / finishing the cylinders is not rocket science - all you need is $2k worth of special tooling attached to your $100k CNC mill and the right set up in your honing station...
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
So for $1500, you would sell a block with pistons, rings, rods, crank, balance shafts and crank girdle? Would the rotating bits be balanced and would bearings for rods and mains be included? Could this be done on a core exchange basis (core being factory block, crank, rods, pistons, balance rods)?
I might be interested in this depending on costs and details. Thanks
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
If you send me your block I will bore and finish it, supply you with new pistons, pins and rings ready for you to assemble. I will make sure the pistons are balanced. That’s pretty much it!
I might be sending you one this winterish (if it holds that long) for some work... this sounds very interesting to me, but would probably go for full tilt you assemble /ballance it for me, so all I would have to do is bolt on items to make it a long block...
Would you also do overbore for the $1500 say from 100 to 101, with pistons/rings/rods? I will definitely be hitting you up end of summer/ fall for some work, unless it goes to Dave... Or a catastrophe happens (oil in engine from my thread...)...
BTW what do you charge for a full street rebuild?
Ummmm...no, sorry. You would have to be a registered charity for that much of a donation!
Although this does raise the question - anyone want to start a charity that donates newly refinished modified Porsche engines to people in need (of newly refinished Porsche engines) haha
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Considering the cranks rarely NEED any work (which can be done at any local machine shop) other then a clean-up, balance check, and maybe a polish, throw in some bearings and a bottom end gasket and you can have a fresh short block for $2500 (shipping included).
Sounds like a reasonable deal to me. I would definitely consider it if I wasn’t able to reuse my stock block and pistons. (And if I blow up this engine, I may be calling you to work on my spare block).
I think it would also be nice to have a more complete short block ‘refresh’ package for the DIYers—new pistons & rings, new coated bearings, refinish bores, cross drill & polish the crank, mag the rods, etc. Maybe offer it as a core-return service where you provide the proper packaging and a return shipping label with costs folded into the total price. Shipping a block is a hassle for the average joe, so minimizing that hassle might be a selling point.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Sure, I can off just about any level of build, I was just starting with the DIY set up as the base cost. I have found that once I talk with the customer they all want / need something slightly different so it gets hard to put a price on a complete short block or a complete engine.
The piston coating is a proprietary system by Wossner. While the coating is important the ring choice is really critical.
The bore size can be 100.5 to 101mm…possibly bigger if you want it! I will need another set of machining tools to do the 104mm block…if the demand is there I will setup for those too.
When I get a second I will see about getting some pricing for the bearings/gaskets to go with the basic DIY kit. I am off to Watkins Glen for a couple of days…
Freight is not that bad - the bare block is under 90 lbs so it can go regular UPS.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Oh yeah - I forgot to mention - the pistons are about 75g lighter than stock (depends on exact design)!!
Stock 951 pistons are really heavy!
