my new testpipe doesn't line up
Old 07-16-2009 | 04:55 PM
dillon410021's Avatar
dillon410021
Default my new testpipe doesn't line up
I just got my SFR 3" testpipe and it doesn't line up. When you slide it onto the wastegate pipe, the holes at the downpipe do not line up. The only way I could think of fixing it would be to take it to an exhaust shop , have them cut it and weld it to make it fit or bend the wastegate pipe on the new testpipe to make it work. I could also drill the holes bigger(make them into ovals) so the bolts line up.
what should it do?
Old 07-16-2009 | 05:05 PM
theedge's Avatar
theedge
Loosen all the bolts on the wastegate (dont remove any), then loosely bolt everything together, and slowly tighten them all together.
Old 07-16-2009 | 05:12 PM
dillon410021
every bolt or just the ones on the dump tube. I don't what a leak somewhere else
Old 07-16-2009 | 05:23 PM
Richgreenster's Avatar
Richgreenster
Call Tim at SFR.
Old 07-16-2009 | 06:36 PM
Rod Thomson's Avatar
Rod Thomson
When was the last time you checked your motor mounts. I just did mine after encountering all kinds of exhaust line up problems. New mounts, all joints line up (within reason) still went to the trouble of loosening all bolts then tighten from the top down. Actually did the header flanges first before the head/header,then back from there.
Old 07-16-2009 | 06:43 PM
dillon410021
I haven't.
how do you check them
Old 07-16-2009 | 06:46 PM
eyeball kid's Avatar
eyeball kid
+1 on loosening wastegate bracket. Same thing happened with me on my 3" LR pipe. Called Lindsey, they suggested loosening bracket, and bingo. Good to go.
Old 07-16-2009 | 06:53 PM
dillon410021
which bracket on the wastegate
Old 07-16-2009 | 06:56 PM
Rod Thomson
You can measure the motor mounts with a piece of wire (coat hanger) in the shape of a "C". Clarks will tell you or do a search here for the exact measurements. One of mine was completely collapsed. The other looked ok but was 1.5mm short.
Old 07-16-2009 | 07:09 PM
Darwantae951's Avatar
Darwantae951
There's only one bracket holding the wastegate to the torque tube. Make sure at least the three nuts bolting the test pipe to the downpipe are loose. You need play in the entire system to get everything in place before you tighten everything down. Whatever you do, I wouldn't let a generic exhaust shop touch it. The flanges are at very precise angles. Ask me how I know...
Old 07-16-2009 | 09:38 PM
dillon410021
the testpipe looks too big for the downpipe. I can't even get a nut on the bolts. the stock downpipe is supposed to work right?
Old 07-16-2009 | 10:47 PM
Darwantae951
I have an SFR 3" downpipe bolted to my stock downpipe. No issues. Had everything loose when I bolted it up.
Old 07-17-2009 | 12:03 AM
cubby944's Avatar
cubby944
I also had a problem bolting up to the down pipe but I think that was due to using sfr's "true" 3" test pipe. The pipe had no neck-down before the flange which made it impossible to get a socket on the nuts. I ended up making indentions in the pipe by the mpunting holes to give some clearance.
Old 07-17-2009 | 12:28 AM
dillon410021
yeah, I just figured out that i have the true 3" one
Old 07-17-2009 | 07:27 AM
Darwantae951
Did you buy new from Tim or third party?
