Traction control ???
So as we've noted in other threads while we love our cars they are from an era gone by. We can modify a 951 in track trim and struggle to beat a stock 997 out of the box street trim. The technology is just too great in many cases. Doesn't mean it's better as far as driver involvement and increasing your skill set, but it exists nonetheless.
So I'm going to utilize traction control on the next project. It will be a track car only. Why I'm starting this thread is to get various opinions as how to go about setting this up. It will be in the ECU that I'm using and we were thinking of just hooking it up to the ABS sensors. Then it's a matter of trial and error I guess in terms of adj the settings. It sounds too simple and I'm sure I'm missing something. Please feel free to voice opinions or experiences.
Sounds like a fabulous project! I think sensing wheel spin is easy (via the sensors, like you say)... the hard part will be controlling the brakes. Might not be too much if you do an aftermarket ABS pump and brain. Remember, our ABS is 3 channel - it operates both rear calipers together if only one wheel is locking up.
To do traction control, you'll have to control the rear wheels independently. That'll take a new pump and an extra brake line to the rear.
What LSD do you have? Might be cheaper to get a Guard 50/80... Did Geo sell his yet?
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
using brakes to act as traction control for a track car? hmmm....not optimum!
Usually traction control is done at the engine management level, E throttle is the best solution. Dropping cylinders, retarding timing is not the most elegant solution.
re: Link g4
I have have the M030 hubs and spindles for the front however the rears are a problem have to install ABS rear trailing arms.
Are there sensors available other than the ABS sensors?
-BB
agreed throttle is the best .. but a good ecu will do it also ..
I good ecu will be running a different map for each gear so you set that map up with appropriate boost and ignightion timeing so you there for have to ask less of your traction control feature's ..
Also these first and second gear maps are a pretty effective base for you 94 octane map..
there are qiute a few half fixes for those who don't want programmable efi .
so dual stage boost control dual stage rev limit.
another option and can do tomorrow is play around with the throttle cam .. i believe the profile on the cam that guids the cable can be messed with and perhaps gives the driver better control ...
I belive 994 NA's people would change the throttle cam fot a more resonsive drive ... what this means is more throttle travel in the in the first half of the pedal stroke .. on a track car whats needed as you push the pedal is is opens fast to 30% thend moves slow in relation to pedal movement ...
there has been much more work on this in motor bikes ..
the problem is that when the throttle is say 74% open it yeilds 94% of full flow.
The serious guys in the modern cars run with the traction control off because they find it too intrusive but I guess if you are starting from scratch you could program it to suit your needs.
Rainman
rather than traction control and its complicated electrics, you could pull a trick from the book of mclaren (what a good place to go for advice)
on their F1 cars in the late 90s they installed a second brake pedal and an adjustable bias valve that let them select a rear wheel to brake under turn-in...that would be a matter of hydraulic lines, no electricals necessary..
"complicated electronics "???
electronics is the simple way to do active chasis control it all starts with a extra valve or pedal then easily gets out with lots of valves .
since F1 outlawed electronic active chasis and driver aids the level of hydralic wisardry and conplication in current F1 cars makes a russian ejecter seat look simple
