CRAP!!! Coolant bleeder screw/ bolt broke
Odd Posts
Dumb me, broke it while bleeding a hot systems ....sprayed a litre or more of hot coolant on the floor.....
Fortunately, I was able to get it out...
Does anyone have a part number so that I can order one ASAP?
Should be: 931 106 156 00
The water neck is show in a different orientation than it should be, but the figure is for the M44.50, 51 & 52 heads.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
You can still bleed the system with a standard bolt - it is not as clean!
I will toss one in with the the LC-1 on Monday!
You are better off with a vacuum based coolant filler tool anyway. No bleeding needed, no coolant splashing all over your motor, no venting and reventing, etc.
I didn't buy mine from this source, but here is a link to the one I use. Works perfectly. You need shop air to use it, however.
http://www.autotestsys.com/Merchant2...gory_Code=COOL
No big deal.
A eazy fix is take your die grinder and grind / cut a short slot in the bolt about halfway up extending to the end (away from head, a bit deeper than the threads. Chase it with a nut or a die and for less than $2 you got a bleeder screw. You can just unscrew it untill the slot is visible, same effect as a factory bleeder.
Odd Posts
Thanks for all the help, guys. Especially, Chris White!
I have the M8 x 12mm 1.0 pitch in there now, and while it is not perfectly bled, I am okay for now, until I replace the bolt with a proper bleeder screw...
