Autothority MAF question
Lazer Beam Shooter
There is a way to convert 28-24 pin. Get with Russell at MAXTune and see what he can do. He should be able to read the 28 pin chip and flash it to a 24 pin chip for you. Either way the Autothourity maf is the better of the 2 units. And will be much cheaper to fix the chip issue than buy a new maf.
The Autothority is better is how? Whats the main difference between the two?
