View Poll Results: Vacuum level at warm idle
12-13
![](https://rennlist.com/forums/images/polls/bar2-l.gif)
![](https://rennlist.com/forums/images/polls/bar2.gif)
![](https://rennlist.com/forums/images/polls/bar2-r.gif)
![](https://rennlist.com/forums/clear.gif)
5
8.06%
14-15
![](https://rennlist.com/forums/images/polls/bar3-l.gif)
![](https://rennlist.com/forums/images/polls/bar3.gif)
![](https://rennlist.com/forums/images/polls/bar3-r.gif)
5
8.06%
15-16
![](https://rennlist.com/forums/images/polls/bar4-l.gif)
![](https://rennlist.com/forums/images/polls/bar4.gif)
![](https://rennlist.com/forums/images/polls/bar4-r.gif)
16
25.81%
17-18
![](https://rennlist.com/forums/images/polls/bar5-l.gif)
![](https://rennlist.com/forums/images/polls/bar5.gif)
![](https://rennlist.com/forums/images/polls/bar5-r.gif)
20
32.26%
19-20+
![](https://rennlist.com/forums/images/polls/bar6-l.gif)
![](https://rennlist.com/forums/images/polls/bar6.gif)
![](https://rennlist.com/forums/images/polls/bar6-r.gif)
16
25.81%
Voters: 62. You may not vote on this poll
86 951, 125k miles, 20mmHg when warm. venturi delete, resealed TB, epoxy sealed ICV, scivision maf +max chips, accuboost mbc, synapse wg, evo bypass, 55# injectors, LR IC, 89 headers+crossover, 2.5" testpipe + B&B catback
17mm HG at 1100 rpm idle
Stock 122k mile motor but fresh head, ICV delete, 3" LR exhaust (cat delete).
I install my cat for street driving and notice no difference in vacuum at idle
20mmHG idle at sea level. Vitesse stg 2 on a 140,000km motor, Lindsey 3", no cat, adj FPR, 72lb injectors, TiAL 38, MBC, Forge DV, SFR IC Pipes, silicone vaccuum lines, Laust VM for engine mods.
Odd Posts
18-19 inHG at sea level at 950 rpm idle. 85K miles. New vacuum hoses, venturi delete, new Vitesse MAF, Lindsey 3" cat delete, cycling valve still in place.
Basic Sponsor
I see you don't have a catagory for 4-5".
Mike or Dave Lindsey
www.lindseyracing.com
U.S. 1-877-943-3565
Other 1-405-947-0137
U.S. 1-877-943-3565
The Impaler
Mike maybe you can help me. I am trying to find out why I am getting only 16in of vac when most are getting 21. I have gone through every single hose and seal. I have pressure tested my intake and been able to find no leaks. My ICV is epoxied, as well as my AOS.
I am freaking obsessed with boost and exhaust leaks. Really obsessed. I must solve this.
What else could cause low vac with our cars?
I have tested the vac with several gauges at different points in the system as well. I have also blocked off the ICV and tested it so I know that isn't the problem.
