944 turbo wastegates
I have a good used Tial 35mm dual-port wastegate for sale, if you're interested. Works great, same dimension inlet and outlet flanges as the 38mm model that replaced it. Silver actuator housing, 0.8 bar (12 psi) spring. Comes with custom 951 inlet and outlet pipes, used gaskets, hose fittings and all other hardware. The outlet pipe could be used to dump to atmosphere, or welded back into the exhaust. Asking $175US plus shipping.
http://www.armchairautosport.com/IanM/100_2009.JPG
http://www.armchairautosport.com/IanM/100_2012.JPG
How many ducks you figure that setup would be wurth these days? I sure would like to have something like that on my car... and teh WG is something I would prefer to only buy once, untill I get REAL SWOLE UP turbo wise...
hey heres a quick question? i purchased a dual wastegatte from lindsey racing and need to know when i install it will i need to tune the engine any or is it a direct swap out and enjoy kind of piece?
