HI-beams flicker
HI-beams flicker
My Hi-beams flicker when going around a corner at night usually around bumpy right hand corners.
I think it has something to do with the combination switch.
http://www.paragon-products.com/prod...613.508.00.htm
do I need to buy a new combination switch or is there something I can do to fix it.
I also have the rennbay head light wiring harness, which I think has nothing to do with this, my Hi-beams didn't even work before the harness change.
1886 951
1886 951
Could be a weak relay... partialy closing on vibration in turns.... just a thought.... can you wiggle the switch while sitting still to make them come on? How about tapping on the relay while sitting still?
try tapping the switch itself... the steering wheel is attached to the firewall right next to the relay panel.. I would rather spend time eliminating a $5 relay than replace a $150-$250 switch cluster to find out it is a $5 relay... Maybe you can try to disassemble the switch cluster and replace the return spring for the arm...
Well, sounds like a switch problem, for the problem described I would persue trying to find a replacement spring (try local hardware shops)... New switch cluster is rather expensive to prevent high beams from flashing on turns...
