Aluminum "welding" HTS-2000...
I found this stuff, HTS-2000:
http://www.aluminumrepair.com/video_new.asp
It actually works pretty well. Did this with a MAPP gas torch tonight.
Aluminum melts at 1230 deg F. The dude in the video said his **** melts at 500 deg below aluminum.... so 730deg.
Not that there's alot under the hood that gets that hot, but I don't know if I would fix an exhaust port with it.
Other than that, it seems like a good option for broken parts.
No question it can hold the boost pressure. It cools into metal that is harder than alumimun. Don't know how crack resistant it might be after years of vibration, but suspect it would last forever. Having said that, if you have the equipment and skills to TIG weld instead, that's a better option for something like an intake. You have to get the metal very hot to use this stuff, and you are best working on level surfaces because the melted material is runny and hard to control otherwise.
Rainman
i brazed a new larger, harder pin onto my shift lever (both steel obviously) with a MAPP torch so i imagine my tool is more than capable of heating the aluminum. aluminum melts at ~1200 and i think the torch is good to like 1500 so i suppose i should be ok...?
Yes - a MAPP torch is the way to go with this stuff. I've made a few aluminum brackets with it, and it's worked very well. (It's actually easy to get the aluminum parts too hot and melt those, too.)
Are you good with sweating copper plumbing? Similar technique.
Rainman
ok cool. im just concerned about it potentially cracking under pressure (imagine something like a home made SFR manifold but smaller lol, custom tank attached to cut off stock runners)
It's real metal... it'll hold vacuum and pressure just fine. (For what it's worth, 1 bar of vacuum will exert the same amount of force as 1 bar of pressure... just in the opposite direction.)
I think what Tom is talking about is stress cracks due to vibration over the years.
