Reliability questions
#31
M, a fairly stock car (chip, 3 bar fpr, and mbc) can run 15 psi all day long. A stock car needs to stay at stock boost, many people will tell you 18-20 psi is ok(with previously mentioned mods). I feel that is a bad idea for 2 reasons. 1. the turbo is blowing hot air. 2. The injectors just can't keep up with that amount of air. I run all supporting mods and run between 13-15 psi. I am also a bit of a chicken and don't want to push it to much. I have another turbo car that everyone says you can run 15 psi all stock, I run 10 psi (just for comparison, I would rather be safe than sorry).
#32
What kind of WHP do you think you're getting at 15psi?
Here's my thinking...
New (rebuilt) LR engine. Deck plate, coated pistons, oil squirters, Standalone system..... It won't really be a "stock" motor, but it has to be reliable for DD duty.
Thoughts?
Thoughts?
#33
waste of money but yes will be reliable DD
#35
All that for 10-15 psi on a 26/6 is not worth the money.
If you want reliability get a honda or toyota otherwise a turbo bleeds money and n/a or s2 drips money
Only way these cars are worth anything is if it's sentimental or you want a track cheater car
#36
Jason, I can't agree more. As for power, I put down right at 240 whp at 15 psi (3 in exhaust, 3 bar, chip, shimmed wg, and mbc). The key is to keep you afr in check and unless you are going to go crazy, a stock engine and DME will work well .
#39
Hey guys, I know it's going to vary a lot depending on how the car has been taken car of, but in general is a 200,000 mile car going to be too much? I drove one today that seemed to be in great shape but it did have 200,000 miles.
#42
Thanks guys. He does have the service records available so I'll ask him for those. I think I'll ask him if I can have a PPI done as well.
What is a well-maintained 951 typically good for in terms of mileage? I ask because I wouldn't want to buy one with 200,000 miles, even if it is in great shape, if it's going to die soon anyway. And I'd also be worried modifying it
#44
Here's my view as a new owner. I've had my car for 6 months. WOW! didn't even realize it had been that long. Seems like 3!
Anyway, I bought the car on a whim. Had money saved up, and have been around here to know about all the do's and don't's of maintenance, and shopping. Test drove the car twice and loved it! Waited a week, then snatched it up.
So far, I've dumped 800 in brakes, a few hundred for belt job and I now have a fuel filter, and CV rebuild kit sitting in the office, ready for my lazy *** to install. I knew I would have to work on the car, and honestly, it's been cheaper than I banked on. So happy!
Next up is motor and trans mounts, bushings, a fluids will be flushed/changed, and I need to have the gaskets replaced all around, so I can start using some very cool, special oil. I expect a few thousand to be missing before I'm done with it.
I'd say the only hard part about all this, is I bought a car via loan, that needs general maintenance work. I wouldn't really suggest this approach, but I'm doing it for credit. And I jumped into it knowing I'd need a fire suit.
#45
