Advice needed on Sparkplugs
Im updating all of my turbo's ignition components, but don't wknow which plugs are the "best" for my turbo, and my new wires...
W7DC Stock Heat Range non-resistor 944T.
WR7DC Stock Heat Range resistor 944T.
W5DC One Colder Heat Range non-resistor 944T.
WR5DC One Colder Heat Range resistor 944T.
W9DC Stock Heat Range non-resistor 944NA.
WR9DC Stock Heat Range resistor 944NA.
wires are Lindsey's Magwire 1200* with the non-resister beru connectors....whatever that means! haha
Keep in mind that this is for a street (secondary) car, running 16PSI with MAX chips. (so they tend to be a little rich)
Any insight will be greatfully appreciated!
Small Business Partner
NGK is the way to go.
For your boost level, I would use either the BR6ES, or BPR7ES. The 7's being a little colder, and the former being a non-projected tip plug (kinda half-step between the regular BPR6ES and BPR7ES).
-Rogue
-Rogue
hmmm... sounds like NGK is the way to go, then! haha.
what's the benefits of a colder plug or a non-projected tip plug?
i need to go do some research...
And I will take spark-blowout over knock any day. Easy fix for spark-blowout is to simply run a tighter gap, or an aftermarket CDI (I have an MSD 6AL-2).
-Rogue
