Turbo water pump wont shut off
Just got my car back together and afte running it for a bit the turbo waterpump keeps going on and shutting off and then it goes on again and then shuts off. Its just keeps cycling. Any clues to what it could be. Ive replaced my DME relay. Could it be the temp switch?
Brian
Brian
Brian
Brian
Water pump should immediately turn off when you disconnect it I believe... if it keeps running the problem is elsewhere... if it turns off and stays off you need a new sensor...
EDIT..sorry, it should run for 30 seconds give or take after being disconnected...
If so...Turbo cooling relay... pull it, get a replacement $176 from pelican, $191 from 944online, or seek second opinion, I would recommend second opinion before buying a 200 dollar relay (it has built in timer function for running the pump after ignition is turned off...)
Or you have the special 8 minute mod?
My mechanic just replaced my waterpump, belts, o-ring turbo and a few coolant hoses and also flushed the coolant and pressure tested my radiator. A full cooling system check up, and found no problems.
Well my mechanic says the temp switch doesn't look stock. I think it's a mod.
maybe you have an air pocket in the system- the sensor sees a higher temp from the air and runs, then the coolant contacts the sensor, cools it down and it shuts off, then the air comes back to the top, comes back on, pumps the fluid till it cools it down...
Yeah that sounds right. that could be happening. what to do ?
From: Brisbane, Australia (Formerly: Sunnyvale, CA)
