stripping the interior
Old 04-09-2009, 02:33 PM
ShApE
ShApE's Avatar
Default stripping the interior
So i started stripping my interior yesterday so I can paint it and install my race bucket seats. How much glue do they use on these cars??!?! I worked on it for a good 5 hours and I feel like I barely put a dent in it. Right now Im using a cordless drill with a wire wheel attachment and its getting the job done....just very slowly.
I'm getting some dry ice to remove the tar mats, but what is a good method to remove the hairy stuff thats left behind on the rear wheel wells and the front of the rear seats?
Any help would be greatly appreciated!
Old 04-09-2009, 02:38 PM
eniac
eniac's Avatar
Use a heat gun to soften the glue then scrape it off. It works on the all the glue, tar mats, and the "hairy stuff". Don't bother with the dry ice, it's more trouble then it's work.
Old 04-09-2009, 02:51 PM
DrZ1
DrZ1's Avatar
Ha HA. Been there, sucks big time. Different chemicals work better for the differnt adhesives. The heat Gun for sure, needs to be a good one. That removed every thing but the adhesive and the yellow stuff with a rough texture what I was told is called "monkey snot". That stuff I used a 2 inch brass wire brush on a pnumatic tool to remove. For the adhesive, I used 3m adhesive rermover, and finished with Oops adhesive remover. The differnt adhesive removers seemd to work differntly. I can't reccomend enough the heat gun.
Steve
Old 04-09-2009, 02:54 PM
Dougs951
Dougs951's Avatar
I guess I was lucky when I pulled my rear seats, nothing was left on the seat well.
As for the rest of the junk stuck to the car, a corded drill or a pneumatic tool will do much better that a cordless.
Sweet Post 666...
Old 04-09-2009, 03:52 PM
shiners780
shiners780's Avatar
Only 5 hours? You've got about 35 more to go!
Yup. Took me 40 hours to strip/clean/paint my interior.
Good times....good times.
Old 04-09-2009, 04:17 PM
Van
Van's Avatar
Use acetone.
High times... high times.
Old 04-09-2009, 04:22 PM
DanR
DanR's Avatar
took me 40 hours as well, do an advanced search for DanR and car interior and you will see my trials and tribulations
Old 04-09-2009, 04:29 PM
95ONE
95ONE's Avatar
+1 for everyone. That is a ridiculous job. Goof Off on rags soaking onto it for at least an hour. But then that just smears the first layer off. Took me a week with a lot of work. VERY HIGH. Lots of headaches. -real ones.- I've been bragging about German glue since then. It's gotta be the best ever. Made from dead Unicorns?
Hang in there. It will get done eventually.
Old 04-09-2009, 04:39 PM
Chads996
Chads996's Avatar
+1 to everything mentioned. I used Xylene. But if you do (like most harsh chemicals) Please use very good ventilation and a proper mask / eye protection. It is REALLY nasty stuff.
The hard work is COMPLETELY worth it.
Old 04-09-2009, 05:40 PM
LFA951
LFA951's Avatar
About how much weight is acutally removed?
Old 04-09-2009, 05:59 PM
95ONE
95ONE's Avatar
Wow. It's like I'm looking at the 4 point I just welded in. Check out the comparison. My diagonal is a little further over though.
Old 04-09-2009, 10:36 PM
Dougs951
Dougs951's Avatar
Hmm has any one tried to sandblast that stuff off yet?...
Old 04-09-2009, 11:08 PM
alxdgr8
alxdgr8's Avatar
Dry ice method might work...haven't tried it though.
Old 04-09-2009, 11:48 PM
95ONE
95ONE's Avatar
Dry ice is almost magical on the tar paper stuff. Does nothing for the glue.
Old 04-10-2009, 12:12 AM
eclou
eclou's Avatar
Received 1,228 Likes on 600 Posts
instead of the heat gun, I used a propane torch - it is a little faster, but a tad more dangerous
Quick Reply: stripping the interior
