Please, post you idle oil pressure!!
#76
After having concerns about having too much oil pressure, upon the fall oil change last year I replaced the oil with ATF and ran it for 30 minutes at idle. Then drained the ATF, refilled with 20-50 ran for 15 min, drained again changed filter and refilled with 20-50. Now at startup I see 4.5 bar, warm engine idle after normal driving is between 3 and 3.5 bar. The lowest I have seen is 2.2 bar after a 65mph second gear jaunt for ~1 minute (italian tuneup) repeated four times with cooling time in between each jauint.
I think the ATF really cleaned out the pipes (so to speak).
#77
I know this is an old thread... I have some new info I thought interesting to add for discussion.
#78
i was looking at this thread because my oil pressure dips to about 2 bar at super hot idle. i just wanted to see what others are getting.
when you start to get into boost at about 3,800 RPM the oil pressure gauge is at 5ish, then does a little blurp dance and goes down to about 4. is this some sort pressure safety valve to reduce pressure? it's always done this.
#79
#80
#82
