Banjo bolt help
Banjo bolt help
Which one is the stock one? I have one with bigger holes and hollow, the other one has smaller holes and is a solid piece. I thinl is the one with the smaller holes but I am not sure.
holes....
the one with the bigger hole in the center is most likely the stock one,,,,kinda hard to tell with no pics, but if your other one looks ike it has a carb jet stuck down in the middle it is not stock. it is a performance upgrade made to increase your boost level from stock. if you aren't sure, play it safe. if you can post up pics i can ID better.
marco
marco
I'm guessing you're talking about the banjo fitting on the intercooler pipe. I have three of them, and they're all different.
One has a restrictor in it with a small hole - I think it may have came with the Guru chips that were in my car (PO was still running the cyclic valve), but I really have no way of knowing. Another one has a carb jet in it - aftermarket that came with Authority chips that I bought off of eBay, but never used. The third one is just open - that one came on a used pipe set that I bought from 944online (no idea what year they're from).
