Lower Radiator Hose Rubbing
My lower radiator hose was soo close to the PS pump that I have always had zip ties around the hose and the metal part of the oil cooler line. The zip ties broke and the PS pulley rubbed through the hose. Is it supposed to be soo close to the PS pulley, or something is wrong? The hose is installed correctly. Has anybody ever had this problem before? I have the correct lower radiator hose.
I used to have that some problem with my 1988 944 NA. I ended up trimming the hose to pull it away from the pump as well as using multiple zip ties. On my 951 I have an inch of clearance.
thanks for the input. The hose is installed correctly ...there is only one way it will work and I have the correct radiator. I think there might be something with the PS belt length.
