spark plugs on E-85 engine
Old 03-21-2009, 09:59 AM
guards red 951
guards red 951's Avatar
Default spark plugs on E-85 engine
what spark plugs do you recomment that I use, on my e85 951 engine?
engine got Haltech E6X with wasted spark(2 dual coils), 60-2 trigger wheel, magnecor kv85 wires and E85.. it will have around 450whp.
since I will run e85, what heat range on spark plug is best? the car is for track only.
Old 03-21-2009, 01:53 PM
blown 944
blown 944's Avatar
bpr7es
Old 03-21-2009, 01:55 PM
blown 944
blown 944's Avatar
or 8's I suppose, for the extended track application
Old 03-21-2009, 03:19 PM
guards red 951
ok, thanks!
Old 03-21-2009, 03:52 PM
95ONE
95ONE's Avatar
def 8's. Sam at pro-technik suggested 9's or higher for enduros.
(ngk standard rating)
Old 03-21-2009, 04:48 PM
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
For enduros, I would use the non-projector tip NGKs...
So, a BR8ES or BR9ES...
-Rogue
Rogue_Ant
Rogue_Ant's Avatar
Double-post.
BTW I run 8's in my 951, which is nearly a DD...
-Rogue
Old 03-21-2009, 08:32 PM
gregeast
gregeast's Avatar
Just for my edification, how are these plugs different, if at all, from what should be run on 91 octane pump gas?
Old 03-21-2009, 08:44 PM
Rogue_Ant
Rogue_Ant's Avatar
The plugs are not different from regular gasoline use plugs... in fact, one can usually get away with a little bit 'hotter' plug on E85 then gas.
For a modified 951 running ~1bar of boost, I would use the NGK BPR7ES or BR7ES. The stock plug (BPR6ES) is to hot for a modified car, IMO.
-Rogue
Old 03-21-2009, 08:45 PM
guards red 951
-Rogue
what do you mean by non-projector? whats the diffrence?
just to make some things clear; 8's and 9's ngk plugs aren't too cold with E85?
Old 03-21-2009, 08:53 PM
guards red 951
-Rogue
I will be running 1.5-1.8bar of boost, becouse of a "small" 57mm SFR Dual BB turbo, P-trim wheel.. I think 8's would be best for me... but BPR8ES or BR8ES?
Old 03-21-2009, 09:46 PM
Rogue_Ant
Rogue_Ant's Avatar
8ES are not too cold for a modified 951. I ran these plugs with both Gas and E85. The car is a little sluggish until cylinder temps warm a little. But not a big deal to me (and a lot of that is due to running E85).
Attached are pictures of a BPR7ES & BR7ES. Easy to identify the difference. The non-projector plug should help to slightly ward off knock.
-Rogue
Rogue_Ant
Rogue_Ant's Avatar
With that much boost, what fuel and what is the cars use?
-Rogue
Old 03-22-2009, 12:05 AM
blown 944
blown 944's Avatar
I have not had trouble using the "P" plugs and have not had trouble with 7's either. Matter of fact I even put 6's in the last go around, knowing I was planning on running less boost and b/c it is a DD and it has been cold out so.......
With that said I trust that 8's are fine as I have been in Josh's car a few times and it doesn't seem to have trouble with starts or the like.
I used to run 9's in my race car with Ethanol and found they would foul out too easily. That car was mechanical injection though so pretty rich.
So I guess really it is matter of preference. I have ran up to 35 psi with br7es so I suppose all plugs from 7's to 9's would be safe and if the 8's or 9's work fine they are safer.
My .02
Old 03-22-2009, 12:28 AM
gregeast
gregeast's Avatar
-Rogue
Thanks for the enlightenment
Quick Reply: spark plugs on E-85 engine
