what is different about 180mph speedometer?
I have a 160mph and a 180mph that I am trying to combine into one that works.
The only differences between the 2 that I can find are the plate with the mph numbers on it (of course) and then some of the resistor values in the circuit board are different.
Does anyone know if the spring/needle drive mechanism is identical? This is the assembly that the needle slips onto.
I would like to swap it from one to the other if possible.
I know, but I have a fried circuit board on one and a broken piece that the speedo needle attaches to on the other. So I need to know if the latter can be switched back and forth, since I see the circuit boards have different resistors.
How did you fry the circuit card in the first place?
Boost gauge is on the Tachometer, no relation to the Odometer, could be done with no ill effect to the rest of the cluster... Maybe I will take this route when I install an AFM and aftermarket boost gauge...
"The circuit card and driver (piece the needle attaches to) are a matched set (I believe) and shouldn't be separated..."
I didn't read this reply until I made the switch....and put everything back in the car. I will report back as to weather it works or not this Spring. The parts look identical and have the same number stamped on them, although I can see how they would be a matched and "calibrated" set. I am ending up with a 160mph because the 180mph one had the bad circuit board.
I am not sure how the circuit board fried, but it has black burn marks on it upon removal. It never worked for me.
So thanks for the offers on clusters/parts, but I am all set, until I find out if this works or not.
