Shop Build
Shop Build ( AC Question)
Since I am setting up a track car I need a place to keep it, and work on it. Also, since my last project of rewiring my car in the carport was such a miserable experience, it could not come at a better time. We moved into the country so I am making good use of the old barns around the property. I would like to get suggestions to make the best of it. I am converting this dairy barn to be a functional work enviremont to keep me out of the elements and have proper lighting. I hope to put a small lift, which I definately need help deciding which would be best. Since I am doing a good bit of the work myself it will be a slow progression. Tommarrow I pour cement where I removed a raised concrete platform used to stand above the cow slop.
Steve
Steve
That is going to be a real challenge to put in a lift that is tall enough to walk under. Looks like a good block structure, any chance you could change the roof to allow at least a 12 foot ceiling? With a two pole lift with the cable going across on the floor, the pole are around 9 feet tall. The problem is the car has to be lifted 7 feet and you have to add on the height of the car. You could lift it less or make a slot in the roof structure just big enough for the car to fit into.
http://completehydraulic.com/
Outside of that, a scissor jack would work but you would still need to be on your back under the car. I never liked to look of them, they just don't look stable.
Pits are not only dangerous but a complete PITA. Not to mention most home owners insurance companies will not cover them.
It's going to be next to impossible to get a lift in there unless you feel like raising the car up half way and sitting under it.
You could get away with a mid rise and still be able to do 95/100 jobs on your car.
Thanks for the input.
I thought about a pit. But it seemed to be a major pain to do. I dont need a super lift, as most work I need help w/ my mechanic. He lives about 2 hours away, so anything major i take it to him. We are working out details for another shop build near his house , as his shop stays crammed. I will have a dedicted spot in his new shop. There a lift or two there will not be a problem. I need a spot here for small jobs where I can work out of the elements and have a nice oraniztion of toos. I have no problem working under my car on my back.
BTW look closely that snapper is force fed and does about 50.
Steve
Steve
