Failed #2 Rod Bearing?
Part of the IN Crowd
Well that is an expensive way to learn a lesson.
It is soo easy to assume everything thing is fine and then poof.
I would tear the entire motor down and inspect every bearing surface again. If you were soo low on oil that you starved a rod bearing going in a straight line you might have only found the tip of the iceberg. Also think about the turbo and possibilities of starving it as well.
Oh, assuming I replace the crank - should I go ahead and replace that Rod too? It doesn't seeeeem damaged but I don't know too much about these things and I'd rather be safe than sorry.
I replaced my connecting rod just to be safe. You can keep the original as a souvenir.
If I had wrecked my car and knew that it was leaking oil I would probably check it quite frequently. But that is just me.
That was not my intention. Hind sight is always 20/20. I did the same thing but I didn't have enough oil and I was on the track. It was 1 qt low. But I was on slicks and apparently that was enough. I got to think that going in a straight line your motor had less oil. So make sure you go looking for more damage.
There is risk of metal shavings being anywhere the oil goes.
Anyhow, I'm planning on doing a full rebuild and making sure everything is within spec as I go. I think I've got a pretty good idea of what all has to be measured, and I've got the Haynes book which gives me specs. I'm going to be very **** rebuilding this, I want it to be strong when I'm done.
On the 996, when you turn the key in the ignition, the digital oil level comes up on the display.
I told you it was rod knock...
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
