ape stage 2 vs linsey max chips+ boost enhancer?
My 951 came to me with ape stage 2 kit with banjo bolt, the car runs great, is there any major change going to the max chips and boost enhancer. If there is no major change I'll just save up for a 3in exhaust. Thanks for the help.
I have run a search but could not find anyone who has used both
Marty
Marty
Part of the IN Crowd
I would save your money.
If you have APE stage2 and banjo bolt the next step is DP wastegate and a manual boost controller. And it is down hill from there.
Quit Smokin'
General rule of thumb is that APE chips seem to run rich in the mid range and lean at high RPM. I have seen cars with APE chips dyno with decent AFR's, so there is a chance that your chips are just fine. My opinion is that Max chips are a superior product, that give better drivability, and throttle response. They may also run a little safer up top helping to protect your headgasket. If I was going to step up to a 3" exhaust I would suggest springing for the Max chips as well. The new chips can be ordered tailored to your mods, which is a good thing since the larger exhaust *may* cause you to run a little leaner.
Marty
Marty
Temprarily Banned per IB
For boost control you want a Lindsey Boost Enhancer, or Manual/Electric boost controller. And before you buy either, make SURE you have a real boost gauge, they are cheap, head gaskets aren't. People run these things blind using the factory boost gauge and then have no clue when the engine goes poof.
I also recommend bypassing the cycling valve when installing any aftermarket boost manipulation device.
Regards,
Russell
I had the ape with the banjo bolt setup. The boost enhancer with the max chips is superior. The boost enhancer brings the boost on sooner than the banjo bolt and it also increased the max boost a bit and the max chips seem to make the car run better and i am more confident that the air/fuel ratios are correct with them. A definite improvment in my case.
Dom
Dom
I've run the APE stage 2 stuff, had the S2 chips originally wit the banjo, the LBE worked much better than the bolt and was more tuneable. car ran ok, and you can run up to 16lbs boost with those chips according to Min, when i talked to him on the phone. However, i tried their MAf set up, needed some help and they told me to buzz off!!! based on that, i did, and tell you to throw thier crap in the trash and get the Lindsey Kit. Dave and Mike have offered me excellent customer service and support and their products are great. since i've tossed the APE ****, i'm gonna get the MAX chips.
3 inch exhaust won't hurt you either!
marco
marco
You just have to remember that if you bypass the cycling valve you will lose the safety of the stock knock control system.
Contrary to what is often said, you can most definitely use the lindsey boost enhancer and the jetted banjo bolt together. The LBE acts like the gain (the quickness of the initial boost rise), but the jetted bolt, together with the cycling valve, still determines your max boost (unless you set the LBE higher than what the jetted banjo bolt would deliver on boost). This is not bad, and you still retain stock knock control (again, providing you don't go too high with the LBE)
As many have said, definitely get an aftermarket boost gauge and also a wideband (this will give you alot of information before you decide a different route).
I still have APE2 chips in my car and have zero complaints about them. The APE chips and jetted banjo bolt have caused no issues in the 6-7 years that I have owned the car (this includes multiple autocrosses and 3-4 hours of track time). There are probably much better products out there, but the APE chips are not necessarily garbage either.
All that said, I have had a set of MAX chips sitting on my desk for about 8 months ... I should probably put them in the car. =p
