AEM Tru-Boost
I have max set at 18psi....
However - most of the time I actually run with it off and default to 1bar - as determined by wg spring.
For my setup (Vitesse stage3) that is about the safe max for pump gas.
I tried 20psi at Bonneville with the stock k26 and altitude, turbo would not do it........ turbo was the limiting factor i believe. No matter what settings it would peak about 14-15 and fall off to about 12 at the top (6000rpm).
It has been a while but I believe I see peak boost in the 3700-3900rpm range for VR stage3, and I honestly don't recall for the K26 setup..... seems a little sooner, but fell off very early
