Pictures of my engine build
#31
The oil pump drive gear goes in, the o-ring is installed, then there is a shim/washer that is installed. Install the Crank key, and timing belt drive gear.
#32
Sounds like you will do a great job. If you want yellow-zinc, there is a yellow zinc plater in Sunnyvale CA called 4D Metal Finishing. He turns things around in about 48 hours and has never charged me more than his minimum of $65 no matter how much stuff I drag in there. If you overnight parts to him on Monday, I bet you'd have them back on Friday. I'm just say'n....
Or...the CopyCad system from Caswell now comes with a yellow zinc system for the DIYer.
#37
Thanks for clarifying about the front seal. I like shiny parts! I would like to rebuild my engine with 214k miles, but would really like to buy a used engine and rebuild it and then swap out engine.
#41
#42
Part of the IN Crowd
#43
I might be a little worried about that stainless drain line after it has been zinc coated.It might spring a leak since the inner line is teflon or rubber.Just an FYI.
Tim
#44
#45
I, for one, will personally paypal you the cost of your favorite six pack when you've finished this a written it all up with spread sheet. This will be priceless for many of in the future, and I'm encouraging everyone to buy you a six pack on completion.
