exhaust leaks around wastegate - advice?
So, I put the car up on stands to take care of a little rattle from the new 3" exhaust (against the A arm mount - engine mounts seem fine so I'm just going to flatten a little spot). While I was checking things out I found a couple little exhaust leaks - at both ends of the pipe from the crossover to the wastgate.
I'm running a TiAL 46mm wastegate w/no gaskets on the flanges - car didn't come with any and I've read here some run without, so have just been letting it be becasue I thought things were tight. Do any of you guys run gaskets and if so where can I get them?
On the flange at the end that connects to the crossover, I'm thinking I'll just run to Napa and get some exhaust goop to smear on/around the donut/flange ... good/bad idea?
BTW, thought I posted this earlier but can't find it now so my apologies if this is a re-post.
I use a 46mm Tial, and it does have gaskets. They are not super easy to find on the internet. I'll see if I can find where I last got a set. Can't imagine it sealing well without the gaskets. Even with the gaskets, I have to be careful assembling it to avoid carbon traces sneaking out.
You the man, Tom!!! Thanks a bunch!
Yea ... I was never too sure about not having gaskets. Hopefully this will help with the boost bleed off ...
Just a heads up for posterity. I ordered the gaskets from the link Tom provided (thanks again Tom) and it turns out they are indeed metal gaskets! Not copper - stainless maybe(?), but they look like they will do the job nicely.
Oh, and a couple pics since I rinsed off the car yesterday and nice weather forced me to drive it today.
