Removing transmission mount
With all the talk of transmission mounts lately i figure ill tackle one of the 'to-do' things on my list which is to fill the stock mount with urethane. Probably a better time to do it now while im not driving the car then later in the year when its my daily driver.
What is the process for taking the transmission mount out? Just reach up there and start turning nuts and bolts.. ? But seriously, do i remove the entire transmission crossbar or can the mount be removed with the cross bar inplace? Is this even possible with the transmission in the car and a cooler coil? As much experience i have working on the 944, i dont often find myself lying under the rear end of the car..so not too sure how to go about taking it out.
Well i guess i just answered my own question, i just didnt look at old enoguh threads.. i stopped around 2006 . Here is one form 2005, written by APKhaos. Man he is the goto guy when it comes to the transmission mounts!
Now the question is, do i urethane up my original 111k miles mount, buy a new OEM mount and urethane it up for $200 + urethane mix cost, or just buy the hybrid mount for $225.... .
Anyhow i figure it dosent sound to bad, but ill probably need to do some careful angling of the crossbar in order to clear that pesky cooling coil.
Replacing the transmission mount is easy peasy. No need to drop the trans.
- support the rear of the car on jackstands - the rear wheels are coming off.
- Support the transmission on a stand, having lifted it slightly with a jack to relieve load on the mounts.
- remove the rear wheels.
- take the nuts off the trans momount bolts. If you get enough 3/8" extensions plugged into each other, you can do this from the passenger wheelwell!
- Use the end of an extension from the same side to drive the mount bolts out. If you balance it right with a jack under the trans, they coem out easily.
- remove the fuel filter bracket.
- remove the transmission mount crossmember [two bolts, one each side]
- withdraw the crossmember through the right wheelwell. I had to disconnect the right lower shock bolt to drop the trailing arm enough to get the crossmember out, but I have 800# springs in the rear. Softer or stock rear suspension will droop enough to clear it. If not, pop the shock bolt off.
Inspect/check the transmount, and remove/replace as required. Reverse the steps to reassemble.
I think you should urethane you old mount thats what Westin did and apparently its working great.
I would like to do this as it would just cost me the urethane ($30). However i have no idea what the current state of my transmission mount is. Would hate to pull the entire crossbar out wanting to reuse the old mount to find its too far gone. Thinking i may just buy the hybrid mount and a fuel filter (needs to get replaced anyhow) and call it a 'while i was in there...' .
How much sway is allowable with the stock mount before its considered shot? When I was reinstalling the engine in my car, in the process of getting everything lined up I realized that I was able to swing my trans close to a good 3 inches. (this was with the car in the air on a lift, so the wheels were at full droop and the axles had the clearance to slide that far)
I took mine out today following these directions but i accidently dropped the jack holding the trans. I'm assuming the engine mounts will just flex with it and everything will be ok. correct? It didnt drop that much but i tend to worry about breaking things.
Location: Encinitas, ca PCA National DE instructor PCA San Diego chief driving instructor
I want to know this too. I can see my shifter moving up and down slightly in response to freeway bumps (800 pound rear springs btw)....is this normal and I just didn't notice it before, or......
My whole shifter was moving on hard acceleration. The whole trans moves side to side significantly.
Herr Unmöglich
I finally got mine dumped out of the car with Wipeout's help on Sunday.
The rubber in mine was so soft the trans would move all over the place even with the entire driveline still in place. I can't wait to get the Lindsey one in place. I have had the car not want to stick in 4th gear under heavy load at the track several times. I really could use the precision and hope that the solid mount helps.
