info on camera mount, stuff related to it
#31
The band-aid reduces the wind noise without effecting the road and engine sound. It works just like a foam wind screen on a professional microphone but a ton cheaper. You can still tell when the car gets over 100 with the windows open, outside of that it is very effective.
#33
#35
If you go to the racing forum there are tons of post on the aiptek. This is my second one as my first one want HD.
#38
#39
I got mine from OG racing.
http://www.ogracing.com/catalog/2-Ca...T-CAMERA-MOUNT
can you mount any cam?
can you put different angle?
it looks to be well made..
#40
The one I have is the same as TonyG's. I like it. It is real easy to install and manipulate. It has three joints with nice ***** to loosen and adjust without tools. The plate on top is just like the plate on a tripod with the screw to attach a camera, so if you can mount your camera on a tripod, you can mount it on this. I'll go take a couple pics of it in the car today.
Yep. And ask me how I know.
The HD cameras with internal HD's will shut down due to the vibration even if you turn off the "drop protection".
They are a no-go.
This is what I use, and I use it with a standard Sony mini DV camcorder ($250 range) with a big aftermarket battery (which will easily last the entire weekend).
Here's my mount. We've all used these for years. Zero problems. Just bolt it to your roll bar and go.
TonyG
About $99 http://www.maximummotorsports.com/in...&cPath=121_128
![](http://www.maximummotorsports.com/store/images/roll_bars/ATP00100.jpg)
They are a no-go.
TonyG
#41
on og website, you can choose the tubing size, but not on the maximum one,,,??
bc i have a 1 1/2" tubing (welmeister harness bar)
and it says it mount on 1 3/4" tubing size...(maximum website)
let me know when you have the pics up
#42
The mount clamps to your bar, they just make different sizes so the curved part of the clamp is not grossly bigger or smaller than your bar. You should use the larger mount with your 1 1/2" bar.
Here's some pics. I keep mine mounted all the time and just put the camera on when necessary. I have mine mounted so it doesn't get in the way of my mirror.
![](http://filebox.vt.edu/users/mwinstan/IMG_0215.JPG)
![](http://filebox.vt.edu/users/mwinstan/IMG_0216.JPG)
![](http://filebox.vt.edu/users/mwinstan/IMG_0217.JPG)
![](http://filebox.vt.edu/users/mwinstan/IMG_0218.JPG)
![](http://filebox.vt.edu/users/mwinstan/IMG_0219.JPG)
#44
Nice pics but you should minimise them a little.
I've just bought this little item and from what I can see it looks great. The film it produces looks very good quality and the price is stupid cheap.
https://www.electricsupercharger.com/products-hero.html
#45
I've just bought this item and from what I can see it looks great. The film it produces looks very good quality and the price is stupid cheap.
