Engine bay pictures of my racer after 6 years evolution
#31
Hans are you able to increase caster any more? We don't seem to mention caster much.
#32
yeh Pat that leading link (from castor block) is adjustable so when he screws it out he gets more castor and with the cut and glassed front end he can go pretty crazy
#33
#34
I don't think you want pre-tension if the frame is straight. The laws of physics wants a neutral state, so as the body flexes, the pretension will want to move the body. Hence if you look at properly engineered tube chassis (Trans Am etc) they don't use bars with pre-loading. The reason most commercially available strut bars have the adjustment is that there is a great variance between chassis.
#36
Those replacement A arms look similar to ones I saw on a 968 racer.
#39
This is a really great thread.
Thanks for taking the time to detail the various modifications you've done to your car for all of us here. After all, sharing is caring.
#41
Awsome thread. So, I have a question... what size is the inlet on the turbo? I am doing some much needed maintenance on the 'Mamba and I discovered -- not sure why I never noticed before -- that the god awfull looking inlet pipe design is actually a result of the fact that the 4" opening of my turbo prevents a single pipe solution; the top of the ALT is in the way. (I'll try to get some pics up her soon)
Can the turbo be shimmed or mounted differently? Can the ALT be lowered by an inch? I'd like to get the air filter to turbo inlet pipe as large and unrestrictive as practical; it's choked now and the inlet pipe is actually smooshed to an oval shape about 3'' in stead of 4". Again, never really thought to pay attention to it before, now it's pissing me off. Constricted airt inlet not as good as freer flowing; how does yours work??
BTW, yes it has been a long while since I have posted. Been slammed trying to make the mortgage. First event is March Barber in AL and it's time to attend to my baby... hope all of you are well and having a good start to the new year. I for one am glad to see '08 in the rear view.
#42
As some of you know my racer is in the workshop to be prepared for the coming season. Lots of the panels are off, have been freshly repainted, and are not remounted jet. Just thought I would take the opportunity to take some pictures and show you some of the
modifications done over the years.
Cheers.
#43
Patrick
#44
Hans, you have one of the nicest race cars on Rennlist. Thank you for taking the time to give everyone an update, and with such detailed technical information as well. It's threads like this that make this community wonderful, where people can share ideas and learn.
Cheers.
Cheers.
#45
Otherwise there isn't any problem fitting an unrestricted 4" inlet.
Easiest would probably be to fit a smaller alternator to get a better inlet path.
