i just put in my new lindsey racing adjustable fuel pressure reg in and now my engine at idle is running rough. its goes from 1000 rpm to 500 and then try to ramp up. my fuel pressure is at around 30psi. Any suggestions??
How do you know you have 30 psi fuel pressure; fuel rail gauge? Even then, if your idle is moving up and down, your indicated fuel pressure will fluctuate as well.
Did you have a stock 2.5bar FPR? If you did, I would be looking at the vacuum lines that connect to the intake vacuuming port. That is close to were you were working.
