Turbo Rebuilder recommendations
Old 12-31-2008, 08:32 AM
Mikeran
Mikeran's Avatar
Default Turbo Rebuilder recommendations
Can anyone recommend a place to get a stock turbo rebuilt? My BOV failed and this is what it looks like now
Old 12-31-2008, 08:52 AM
Mikeran
Mikeran's Avatar
Oh also need recommendations on a replacement BOV, should I go stock or aftermarket or what?
I am on a bit of a budget as well so reasonable costs are important to me
Old 12-31-2008, 09:49 AM
gt37vgt
gt37vgt's Avatar
waste of time and money just get another good 2nd hand one here they out last the car when things arn't dropped in them and they are comparably more to rebuild.
If no one else gets one out I think there is one at home might be missing a bolt or have a broken stud but you can just strip that one you have .
I'll be home in 6 to 10 days
Old 12-31-2008, 09:50 AM
fast951
fast951's Avatar
If you do not plan on upgrading the turbo, you might want to check pricing on a new unit or a clean used one. Rebuilds when done correctly are not cheap.
Your compressor wheel is gone, I have a few good used ones (left over from the cheater turbo upgrade) if you need it.
John
Email
www.vitesseracing.com
Old 12-31-2008, 09:51 AM
turboted
turboted's Avatar
Are you sure that your problem is the result of a bad BOV? From the looks of that compressor wheel, your turbo chewed on something.
Regardless, I had a good experience with www.turbo-performance.com in CA. They sent me a rebuilt K26 cheater turbo for a few hundred bucks + core...service was top notch.
Old 12-31-2008, 09:53 AM
Mikeran
Mikeran's Avatar
Thanks I thought about just replacing the impeller since that is all that is wrong with the turbo but was told I could not replace it myself as it has to be balanced.
Old 12-31-2008, 09:54 AM
gt37vgt
gt37vgt's Avatar
yeh his BOV blew chunks in the recirc pipe
Old 12-31-2008, 09:55 AM
dillon410021
dillon410021's Avatar
what do you mean by your BOV failed. Did it drop something into the turbo or did it stop recirculating air or what.
Old 12-31-2008, 09:56 AM
Mikeran
Mikeran's Avatar
Yes what happened was I was a full boost and then let off the gas all at once, I heard a pop and the car quit, I opened the hood and found the large vaccuum hose on the manifold had popped off. I put it back on and the car started right back up and ran smoothly, but when you put the engine under a load there was an aweful howl, took the Jboot off and thats what I found.
I was told that it was probably my BOV that failed and the pressure ruined it, I can't find any method to test the Valve either.
I appreciate any help, this is my first attempt at fixing up a car, needed a new hobby and found this turbo car at a garage sale and have been working on it for the past 3 months.
Old 12-31-2008, 10:18 AM
dillon410021
when you put the hose back on, In between shifts was the BOV making the "psssh" noise like a normal one would do.
Old 12-31-2008, 10:21 AM
gt37vgt
gt37vgt's Avatar
an old bike tube hosed clamped to the snoat and fold it over on the other end and vise grip it then pump the tube up to 20 psi and squirt saopy water on or dunk it in the sink.
you can can just carefully screw another wheel on carefully there is a reasonable chance of success use a T bar and 2 hands to not put any side load on the shaft ..
gt37vgt
gt37vgt's Avatar
Old 12-31-2008, 10:58 AM
Willard Bridgham 3
Willard Bridgham 3's Avatar
I forget their name, but call Porsche NA and get the name of their rebuilder. Excellent work, not cheap.
Old 12-31-2008, 11:30 AM
blown 944
blown 944's Avatar
I will be pulling probably the cleanest stock turbo I have ever seen off of a car this weekend.
PM if interested
Ski
Ski's Avatar
The guy that LR uses, retired in OK City, used to work for a guy names Penske, in an old racing series called CART.
Quick Reply: Turbo Rebuilder recommendations
