Need advice on damaged turbo
Hey, I just picked up this turbo, it is in overall great shape but there seems to be a gouge in the center of the hotside wheel. Will the turbo run properly in this condition? Was material removed to balance it? Can it be rebuilt? The rest of the turbo is in flawless condition and the fins on the hotside are all perfect even directly under the gouge. Thanks for your time in advance.
-Nick
-Nick
If the modification you are looking at was done correctly, and there is no problem with the turbo, just use it. It appears that you purchased this turbo used, did the PO mention anything about a problem? If you have concerns, have it checked/rebuilt.. Email if I can assist.
