injector seals
injector seals
Does anyone know if I can pick these up locally like from an autozone\checker or hardware store? Or am I stuck to order them. Im in las vegas and these are for stock injectors
I once tried to match them at a NAPA store without much sucess. I think they are a standard metric size so you may have better luck than me. If you find something keep an eye on it for a while to make sure it is compatible with gasoline. I ended up ordering the whole seal set from one of the suppliers that it is sponsor here and replaced them all.
I'd send them to www.WitchHunter.com in WA and have them cleaned, flow matched, and re-sealed. Costs all of $76 and they 2 day em back to you. There is one on the east coast too that works too but forget thier name.
Another satisfied witch hunter customer. I sent my S2 injectors out on a Tuesday and had them back on Friday. They Also clean the outsides too.
They will install new caps and everything else, and send the old parts back too. Well worth the money!
http://www.paragon-products.com/prod...63.133.557.htm
these are under the 944 section but say they are for 924 do these also work on the 944 turbo? they look a little bigger.
You can pick them up at most auto parts stores. I use oreilly's, and they carry the borg warner part. I think I have posted the part number multiple times in the past, but if you can't find it, I'll dig it up.
