Electronic boost controller recomendations?
eniac nah my piont was that that factory system pulls 3psi of boost of when .
an kool
"bite it off and chew like hell"Peter Brock RIP
you can still do the fine tuning of the curve with ebc in the EMS and have a adjustable bleed as well that will adjust the max boost .
can your ems do multiple maps ?
that way you just match boost pressures with fuel types and have a map for each an if able to be done with an external inpt only allow the crap fuel low boost in first gear .if its not for feul why would you change the boost ?
so you realy need differnt maps including boost
an kool
I went from Profec B to Apexi AVC back to MBC. Love the MBC. 1st gear 18psi, 2nd 18psi, 3rd 18psi, 4th 18psi, 5th 18psi. Each and every time, spot on, rock solid. What can I say. It really is set and forget. The EBCs just seemed to be too temperamental and often had boost creep.
an kool
an kool
I have two different boost maps on my AVC-R. One is for 94 octane gas, the other is for E85. I had to adjust the duty cycle quite a bit on E85 as it gave me much more boost sooner so if your switching fuel types often then I agree, you do need multiple boost maps as well.
AVCR - I you like gadgets and are geeky.
Profec B or Blitz - If you like simple set and forget and need some fine tuning or had issues with a MBC.
MBC - Simple, basic, cheap, works, proven.
yeh you need to rig it up so the Dme sees a reduced pressure signal and doesn't go into limp home but so the duty cycle still influences boost .
yeh i intend to set mine up so first gear only sees a 94 octane map 98 octane second gear and 107 /E85 for 3rd to 6th
It's actually not that bad to set it, just takes some driving around and flooring it in third gear, I set mine to 14 psi in third and never touched it since, does require some patience and playing with the **** though...
