Dualport wastegate...Really worth it?
Old 12-08-2008, 01:21 AM
Cory9584
Cory9584's Avatar
Originally Posted by Paseb
something i should consider buying new?
If you can find a used one that would be fine. They're pretty bulletproof
Old 12-08-2008, 01:23 AM
gt37vgt
gt37vgt's Avatar
hahah yeh these people have air conditioning and electric seats but I'll remember
Old 12-08-2008, 02:21 AM
VOoDOoGTX
VOoDOoGTX's Avatar
i ripped my AC out haha
Old 12-08-2008, 02:33 AM
944obscene
944obscene's Avatar
Didn't think the stock wastegate bled that much. So getting a new wg, dp, and mbc would be a good combo? Even on a k26#6?
Old 12-08-2008, 02:48 AM
ehall
ehall's Avatar
Originally Posted by 95ONE
you'll hit boost sooner From a spring that is new and not 20+ yrs old. You won't get more power from the same psi. just to be clear.
This is the real issue, IMHO. Do it and buy the Tial, though my LR DP served me well.
Old 12-08-2008, 02:54 AM
theedge
theedge's Avatar
Originally Posted by gt37vgt
i can't understand why any one would bother with anything other than the lihndsey one
i just cut up my old one an increased the spring pressure and have inline check/ Lindsey boost enhancer thing i set the waste gate and the valve up on the bench.
i put the time in . but if lihnsey don't give custom spring pull it out an buy one and its done tial wastegates are fashion accessory's
Fashion accessories Tial is much better than the stock one, even a modded one. Just the fact that there are easy to source replacement parts make it much better.
Old 12-08-2008, 03:13 AM
ehall
ehall's Avatar
add a 3" exhaust and yes.
Old 12-08-2008, 03:23 AM
944obscene
944obscene's Avatar
Where can I look to see what people would gain from this little combo?
Old 12-08-2008, 03:34 AM
ehall
ehall's Avatar
do asearch here. LOTS o info. LR is close to you. They would probably a good group for you to work with.
the 3" exhaust issue is usually based on an old cat. Full 3" will allow faster spool up. It's noticeable. Good WG is also noticeable.
These are basically the first mods to make.
Old 12-08-2008, 04:06 AM
944obscene
944obscene's Avatar
Damn, they are close aren't they? I never looked down at the bottom of their site for a location, or contact info. Looks like I'll have to save up my allowance and go have a field trip at the toy store.
Old 12-08-2008, 05:39 AM
333pg333
333pg333's Avatar
I guess the advantage of the LR one is it is a modified stock and therefore a direct replacement. The Tial does take a little bit more work to make fit and there is not a lot of meat on the edge of the flange to provide the best seal. Perhaps I'm in the minority here, and to be honest I wouldn't not use a Tial in another application, but I did have my Tial 38 jam shut and I boosted up to 2.1 bar on the track with a helmet on and couldn't hear my engine pinging it's brains out. Car was quite frisky all the same Can't believe I got to drive home that day! I believe the larger Tial has a better fitting flange?
Old 12-08-2008, 06:00 AM
gt37vgt
gt37vgt's Avatar
anyone want to the discuss the physics off this issue or just all by armarni wastgates.???
Old 12-08-2008, 06:29 AM
ehall
ehall's Avatar
DUDE! Armani makes wastegates?! I'm so getting that! It will match my business wear perfectly!
Old 12-08-2008, 07:03 AM
333pg333
333pg333's Avatar
You guys are just too fun-fun-funny.
Old 12-08-2008, 07:12 AM
ehall
ehall's Avatar
Generally, I agree. If you get the Tial from SFR, Tim has done the research to take care of that. We all know about his quality control, which is as good as it gets. The 46 mm Tial will do fine, but I still haven't found an issue with my 38mm.
Quick Reply: Dualport wastegate...Really worth it?
