WTB Spring tensioner triangular piece **updated Technical question please help
I need the whole assembly. It didnt come with my 89 block.
I cant use mine since I have an 86 block..I believe its from 87 onwards
yeah its sort of like a triangle with a sprocket and a spring. This is off an 89 S2. I was just checking part numbers, and they appear to be different for the turbo block so I'm not sure this would work for you.
Ok so ive still got people telling me the s2 tensioner is different and not sure if it will work. They do have different part numbers. Can anyone confirm if the S2 tensioner will work on my 89 944t block ?Please advise....
Thanks in advance!
Thanks in advance!
