Quick A/C question (Voodoo look here)
Thanks. Unsure about the oil, didn't really check and it's 45 minutes away at my parents house at the moment. Voodoo did you drain the oil before shipping it or is there still some oil in it?
I always thought the dessicant also goes bad (saturates) over time and with use, and that's why old AC systems smell like humidity right as soon as you shut them off. I always imagined that if I replaced my dryer that smell would go away....
So, in answer to your question, the car should smell like moisture after the a/c is turned off because its blowing out all the moisture from the evaporator. There is no way to smell the desicant in the car because that is part of the sealed system - unless you have a brake in the lines in the cabin, but at that point I think you'd be more concerned with the freon than the smell of a desicant bag.
