The 2.7 big bore turbo runs!! Yes, videos of course
#31
Brian she runs like a champ! When the time comes, take us out for another ride. This time a bit more adrenaline rush
. What wastegate are you running? Atmospheric?
#32
Might be a short while before I can really step on it, my tires are 8 year old junkers thanks to the PO, im replacing those ASAP with Nokians. I dont quite trust them
Ill take another video tomorrow once the ignition switch is fixed ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Right now no real boost control, im doing it the 930 way and using the 7PSI wastegate spring :lol: I will connect it up soon. Wastegate is a Tial 38mm. Yup, currently open downpipe and thus open wastegate dump. Ive gotta take it to a shop and get the exhaust made. Ill probably do that in November while im in Philly for business, if the shop can fit me in.
#35
Well after a new ignition switch and a new starter, ive been driving around for the last 2 hours or so. The engine hasnt blown up yet so presumably im doing something right, or at least something not completely wrong..... I even accidentally got into boost, as seen in the picture below. The Stage 2 spools so goddamn fast
The spike to the right of the line down the middle is 7PSI, which is the wastegate opening. Nearly scared the **** out of me when it opened
It built 7 psi almost instantly!
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
![](http://thedge.info/my951/round2/oct31-drivingaroundmore/accidentalboost.jpg)
#38
Thats my power steering delete hose. The rack is filled with fluid, and that hose lets it cross back and forth between the sides as it turns.
#39
Brian,
You are using the power steering rack filled with fluid and a crossover line to allow fluid to bypass internal seals? Is it difficult to drive on the street?
Thanks.
Tony
Thanks.
Tony
#40
The steering effort seems the same or a bit less effort as when I had the power steering belt removed.
#42
http://video.google.com/videoplay?do...97570501&hl=en
A crappy video I made last weekend at 1AM or so. My camera doesnt do well in the dark obviously, and I couldnt drive worth **** trying to juggle it
In this video im not driving with the headlights on, just the fogs and Euro driving lights. Theyre quite bright.
Tomorrow im installing a manual boost controller to try out some higher boost runs.
#43
Monkeys Removed by Request
#45
Reno it's AC/DC !!!
Brian, you got to get a camera mount mate. Makes life much easier. Car has a nice burble to it though.
