Help identifying a turbo please . . . . . . . . .
Hi guys. I've been offered a new turbo but I'm having a little trouble identifying it, can you help ?
From the guys inof it's a K27 ? But he doesn't really know much more about it, so I need some info from the Turbo gods on here. What size is it, what size hotside, what spec/tune of engine it'd be suited to for a 951 etc. will it fit on a stock car setup or would I need to go MAF etc. etc.
Identifying it would be a start anyway, so here goes . . . . . . . .
Sorry for so many pics guys, I just wanted to make sure you had all the info in case there was a signifcant marking on one which solves my mystery.
Thanks in advance for any help, there may be a second available once I know what it is and sort out a price.
Cheers,
Mike
Cheers,
Mike
check inside the hot side for an A/r numer . it does look a shade on the big side for a standard averything car i would say exhaust injectors and maf its worth 1 to 400 bucks looks brand new . you will probaly be able to swap it for a Cheater type k26/k27 6 or 8 wich is more suitable for a standard car with some one who has MAF and exhuast
Well, I say standard, perhaps I spoke to quickly. My car actually has a chipset, induction kit, exhaust and a boost enhancer. Very soon to be going to 3 bar fpr, maybe injectors (if needed), dual port wastegate and boost control (either mechanical or poss electronic).
Unfortunately I don't have access to the turbo right now, so I'm dealing with someone remotely trying to get me the info.
Is it a K27 like the guy thinks ?
Will it fit my car ?
Would I need a MAF setup or will that just enable me to get the best out of it ?
Can anyone identify the hotside from the dimensions shown ?
Cheers guys, do appreciate the help.
Mike
Mike
Can you write the measurements that you've taken Mike?
So what number hot side does that equate to guys ?
From doing some reading on here (I'm trying, but my knowledge of turbos's is lacking at the moment - not had the car too long, so I'm just learning about forced induction really (quickly lol)) a K27/7 or K27/8 would be reasonable for me (providing the price was right) I'm well aware there will be much better turbo's out there, but I'm just looking that this could be a reasonable cost upgrade from my standard 26/6. Decent performance increase without smashing my piggy bank.
Cheers guys.
GT37vgt, do you think it'd be suitable for my application ? Was your valuation in Aus$ or US$ ? (either way I'd have to convert it to UK £ haha)
Big thanks, hopefully this may be a go project !
Mike
Cheers guys.
Mike
well i kind of meant either dollar because i was relating the turbo to the market it lives in .
so i paid 300au shipped for an almost identical turbo but not as new .
pros of this turbo are bolt in not easy install on many other cars wich tends to make them cheaper big enough to captilaise on future upgrades . 400 or so hp
Cons are "apparently " not as technically advanced as other stuff a tiny bit big for standard AFM.
run a search on this forum K27 you will find plenty of happy people .
