CPRacing:SPLITTER FLEX?-90mph-115mph
You would need to ask you paint shop that one. It can be painted like any other piece of your car. However to execute that kind of brutal flexing and not expect to lose any paint might not be realistic. Although I believe that they can add an elastomer (e.g. silicone elastomer) to your paint which will aid in expansion properties. Keep in mind this is done at a rate of 10 to 30 parts by weight of at least two acrylic polymers, copolymers, silicon or silicon derivatives in aqueous emulsion form depending on which combination of, or if crosslinking is employed....although you shop may have a better method, as this is generic calculation.
I'll be up for a couple of the V1 splitters. I'm assuming from what I have read that the V1 is similar to the AIR splitter, correct? Honestly, I do not think I will paint mine. It is a breath of fresh air to finally have a rubber like splitter that retains the factory black look. The black/red contrast has always been a favorite of mine. Cheers for creating a factory looking alternative to the AIR splitter.
Monkeys Removed by Request
I'll be up for a couple of the V1 splitters. I'm assuming from what I have read that the V1 is similar to the AIR splitter, correct? Honestly, I do not think I will paint mine. It is a breath of fresh air to finally have a rubber like splitter that retains the factory black look. The black/red contrast has always been a favorite of mine. Cheers for creating a factory looking alternative to the AIR splitter. ![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
I will be...but not unitl the 951/952's are taken care of first. Not to slight the N/A, but the idea and support began here with the turbos...also I have seen little in the way of the N/A's requesting these, at least not after the first influx of 10-15 inquiries/orders.
*Dillon...did you replace your sensors yet?
*Dillon...did you replace your sensors yet?![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
, so It will happen this year.
Stupid question: did I read somewhere that the V1 was going to work in conjunction with the stock batwing? I.e., both will be on the car together? Sounds odd...
I'll def be getting one -- the question is when I can afford it! But I, too, will not be painting mine. Red/black looks sexy.
