rabke fluid warning light
under braking the dummy light flashes with brake fluid light, my brake fluid level is fine.
is this a common problem? wire short somewhere? easy way to fix it?
Mine doesn this when the fluid level is barely above the min line. If your fluid level isn't at least 1/2 way between the min and max lines, add fluid and see if the light comes back.
