lets take a pole.
I blew my engine the other day
what do you think i did. I got a hole in my oil pan large enough to put my hand through it
tomorow ill have the engine out and tell you exactly what i did.
Pumice King
I think Lorax already took a pole...
https://rennlist.com/forums/off-topic/454576-impaled-myself-graphic.html
The Impaler
i think you dropped a valve, probably exhaust valve head. this smashed the piston. the piston pieces get caught between the rod/crank and the pan. pan smashes. if this is the case then the block will be rooted too from the rod running up and down the wall.
Sean
Sean
Apparently...ah no forget it.....
