Electrical weirdness Buzzztt/white puff
#61
This is weird. Electrical diagnosis always drives me nuts.
The blue wire goes to the alarm control unit, and is also connected to the G2 relay through fuse 18. Since you have no alarm, i guess this is bridged in the factory harness somehow. Actually, the way I interpret the diagram, relay G2 closes with the key on, and energizes the blue wire to "excite" the alternator field.
Check for continuity of the blue wire at the alternator from relay G2 fuse panel position 87 IIFRC. I think something is wrong with the circuit of the blue wire. Does position 30 on G2 have 12v?
#62
Battery read 13.3v (charged overnight) as I left home this morning, 35 miles, 5 starts no headlights no a/c or wipers, battery reads 11.8v upon returning home
Dash guage tends to read 1 volt less than actual
#64
Sorry, I was asking how much current is being drawn from the battery -- you do this test by connecting the multimeter in series and seeing how much current (in amp or mA) are passing through. I was just thinking maybe there is some large drain, but based on your last note, it sound more like you are not charging for whatever reason. I looked at the back of any old alt, and presume the noise reducer is the black one-wire component? My rebuild bosch came with its own new one...
#68
Hi David
Was the ignition switch on when the short happened?
If not then any damaged caused by the short "should" be limited to the current path provided by the short.
I would double check the connectors at all points between
batt and alt. including starter.
I would double check the ground connections.
A standard DVM isn't the best way to check for shorts between cables . A meg ohm meter is required to get a good indication of insulation brakedown between cables or
between cables and chasis.
The diode test mode on the DVM will work a little better
checking for shorts than the continuity mode.
I did read all of the posts, and they started to backtrack a lot and get my mind all jumbled up. There is a simple sollution to this. Keep your diagnosis within these two wires going to the alternator. My guess is still the one from the battery. You have an open circuit not allowing the current to complete it's path. HTH.
#69
For a number of years I made my living diagnosing
electrical/electronic problems, while I haven't really studied the schematics in full, logically this is where the problem should be.
#70
The black component on the rear of the alternator I have is a
capacitor for noise reduction.
After looking into this a bit more, I agree with cruise98.
The blue wire at the alternator should have 12v on it with the key on, if not this could be the problem.
#71
1.6 v with the key on at the blue wire, grounded to the alternator case
This is with a new blue wire run to the firewall connector, where does the blue wire run from there.. to relay pin 87 ?
#72
That voltage (1.6V) agrees with what I measured, there is a light bulb in the path that drops most of the voltage. The bulb is the alt warning light. Sure is a strange problem.
#73
Some tests that I would try if possible.
Remove batt cable from back of alternator. attach meter to
alternator. Start car and see what the alternator is putting out. If it is generating voltage then re-connect the batt line.
Disconnect the alternator cable from the starter. Start the car, check voltage at the alt cable by starter. If voltage
normal re-connect alt cable to the starter and diconnect the power feed from starter to ABS module. Check voltage again. If voltage normal then could be a problem with the ABS module dragging the voltage down. your starter is working normally? so probably not a short in it.
This will isolate the cables as potential problems.
If you remove the batt cable from the back of the Alternator
and don't see it producing voltage, then attach a jumper cable from the negative batt post to the alternator case.
Check for voltage at the output of the alternator.
If its working, you have a bad ground.
If not working then I would disconnect the blue wire from the rear of the alternator, attach a 12v source to the alternator with it's negative on the case of the alternator.
Start the car and see if the alternator works. If it does then
you know the blue wire circuit is bad. If not then it's something with the alternator.
You can check the capacitor on the rear of the alternator,
Diconnect it, put your DVM across they usually fail open ,
if you see it "charging" then it is ok. If its a dead short then
it might be shorting the alternator.
Hope some of this makes sence and helps.
If not ............
If not ............
#75
Check 1) with everything connected normally, the large + at the alternator reads 20.3v grounded to the case.... good correct ? car running
Check 2) With the neg cable disconnected from battery there is continuity from the neg battery post and the blue wire at the alternator.....
