Interest in a New Splitter?: UPDATED!
#616
Darren,
Are you refering to the last 2 OEM holes close to the fenderwell?
If so, abandon those and use the provided zip screws. Install all the frontal hardware then when you get to the last 2 side attachments, slightly pull/push the OEM nose edge to align with the V1 and zip screw from underneath.
#617
Yes...OR you can pilot a single new hole and thru bolt-it.
I abandoned the pre-drill in this area, because not all of the cars were lining up exactly the same. It seems as if time, environmental conditions..or whatever makes the outside edges just a wee bit different.
It was easier for most to simply attach along the entire front...then slightly push/pull the extreme lip edge to match perfectly and run a zip up. Also make it a cinch to remove.
I will be more than happy to provide some new thru-bolts at no cost if you need them. Let me know.
PATRICK
#618
I've actually scraped twice in the past 2 days and never scraped anywhere before. Both times coming out of parking lots onto a main road and I was barely moving. I can feel a little roughness underneath - nothing bad at all, but the top still looks new . The front lip of the splitter is 6" off the ground. I guess I'm going to have to start remebering these parking lots ... Very, very happy with this splitter!
#623
#624
Roughly half hour but that includes drilling holes for the under trays that I didn't install, I wanted to drive .
#625
I received the hardware today (priority mail). Thanks for sending it yet again. It's the only hardware package I've received. (Nothing through UPS.)
Just to be sure --
Is there no hardware for the rear of the splitter, where it attaches to the plastic undertray? If not, I can fab something.
Thanks.
Just to be sure --
Thanks.
#626
Not Special
Just to be sure --
Thanks.
Just to be sure --
Thanks.
#628
I would expect, if I'm not mistaken, that subjected to the heat of the engine, it might start to sag over time. I'd rather be safe than sorry. No need to risk tearing it (or the front fascia) off while backing up over a gravel lot, pothole, or some other uneven pavement.
#629
That's not a legit worry. It will be fine. The stock batwing doesn't droop, and a huge number of folks don't have the belly tray. If you're worried, drill a few holes and match then up to the belly tray. I keep my stock piece connected with zip ties, so that I can get it off faster.
#630
Chris,
There should an extra 1 or 2 zip screws in your pack. I included these so that those who wished to attach but did not have existing attachment points could simply run a zip up through the splitter to the OEM plastic undertray.
I have had mine in place w/o any rear attachment for 2 months now and have had no issues, although it is more for ease of swapping proto units back and forth for trials. When it is all said and done, I will run 1 or 2 zips through just for peace of mind, although I am still not convinced it is necessary.
