Oil, what oil?
We realized the oil lubrication problem a couple of years back and have been heavily pusing Joe Gibbs oil and recently the ZDDPlus additive. Everybody should pay very close attention to that article. Just because your motor hasn't failed yet, doesn't mean it's not on it's way out. In particular, the flat tappet lifter valve train. Motors we have seen opened up after running these products show litttle or no wear.
Joe Gibbs Racing Oil
ZDDPlus Additive
ZDDPlus Additive
Yeah, Charles said something about that. Sure, replace all the seals and all goes away. However, there is something to do with the grade of synthetic and it's almost magical ability to shrink seals.
Thanks ehall for posting the article.
Thanks Mike Lindsey for being the man in the know.
I switched to synthetic at 115k miles and had to fix two leaking front seals. I just got back from a 2,100 mile trip, used 1/2 quart of Redline 15W50 oil (despite some long hard boosts in hot weather with A/C on), no oil leaks and the oil still looks new. Engine now has 126k miles and a dozen track days on it. Redline made a believer out of me.
Synthetic oil does not shrink seals. It does, however, do a much better job of cleaning sludge out of your engine. If your seals are being sealed with sludge, switching to synthetic will make them leak. Fix the leaks and have a clean, happy engine.
I run the AGIP 4T. It may be a bit thick for Boston winters, but it works great here in Florida. 10w30 oil, in any of our cars will probably leak pretty well, unless you are on a fresh rebuild with MUCH attention placed on seals and gaskets.
10w/30 really not a great idea for our cars unless your name is Mr Claus.
Look at how low a temp range 20w/50 goes AND you get all the extra protective benefits of a heavier oil. Possible downsides is a fractionally worse mpg result. If you're worried about mpg this is the wrong car for you.
If I were brave enough to switch my low mile stock original motor over to a synthetic, then the Agip 4t would be on the short list.
Location: out in the sticks and flat lands of va wondering around for an open field or pavement!!!
I usually go away from the pack and run castrol syntec 5w-50. Which i always run after i rebuild an engine with new seals. Before a build or just an old engine I stick with a non syn oil of castrol 20w-50. If the engine has ran regular oil for a while even on a rebuild i wouldn't use synthic because like Ehall was sayin and alot of us know you WILL have leaks.
Just ckecked the back of a can of Mobil-1 5w50 it reads Meets API SM CF ACEA-3
B3.B4 MB229.3 MB229.1 (VW505.00) PORSCHE APPROVAL 2002
The 5w40 Mobil-1 truck oil meets API CI-4/ch/4cg 4/cf
Gasline engines meets SL SJ
From what I understand this oil meets our needs for ZP protections.
