FS: 87 951 Race/DE/Track/Street
I'm selling my 951 race car. It is a race car but it is also street registered and passes WA state emissions. It would be a great car for track days, racing or just fun on the road. It has an SCCA log book with 15 races between 2003 and 2008. The engine was replaced in 2005 and it has run 5 races since plus a few drives on the street (not a lot of miles). The suspension is well setup, runs great and pulls hard. The interior is stripped and a very nice custom roll cage is installed. The cage is tight to the roof for max headroom and includes anti-intrusion bars in the foot wells. The car is straight and clean but does have a few very minor cosmetic issues. Clean Title in hand. This car has a ton of potential. Asking $12.5k.
Suspension:
-Fabcar Control Arms
-Racers Edge Castor Blocks
-Custom Valved "Turbo Cup" Bilstiens
rebuilt early 2007 & rear shock bushings replaced w/spherical bearings
-Rear Coilovers w/stock torsion bars, Racers Edge lower shock mounts
-Eibach Springs (650# front, 300# rear helpers)
-968 MO30 Sway bars (30mm, 18mm)
-Front Sway bar bracket reinforcement
-Racers Edge Delrin Rear Sway Bar Mounts
-Ground Control Camber Plates
-Rear control arm sperhical bushings
Brakes:
-Large "S4/Turbo S" front brakes
-Stainless Brake Lines
-Non ABS Car
-928 Bias Valve
Engine:
-approx. 75K on engine (installed 5 races ago)
-New rod bearings, Sachs clutch at that time
-K26/8 Turbo
-MaxHP Chip
-Lindsey Dual Port Wastegate
-Pauerman Fuel Lines
-3Bar FPR
-WebCam cam
-A/C Delete
-KISS Supplemental Oil Cooler
-Reliaboost
-Solid Engine Mounts
-K&N Filter
-Freshly Serviced Injectors
Transaxle:
-S2 Gearbox (new old stock)
-80% Locking ZF LSD
Body:
-140k miles on straight chassis
-One Piece Fiberglass Nose/Splitter
-968 style rear wing
-17" 968 Wheels 7.5, 9 widths (not aftermarket)
-Toyo RA1 Tires (still showing some tread)
-Front Tow Strap
-Rear Tie Downs
-Electrical Kill Switch
-2850# Race Ready/No Driver
Interior:
-Welded in Custom Cage
-Carpet/Insulation Removed
-Sparco Drivers Seat
-Corbeau Passenger Seat
-10 lb. Halon Fire System
-M&R 5 Point Harness Belt
-Window Net Mounting
-Dino Steering Wheel
-Air Bag Delete
-A-pillar Boost Gauge
![](http://forums.rennlist.com/upload/ext1sm.jpg)
![](http://forums.rennlist.com/upload/ext2sm.jpg)
![](http://forums.rennlist.com/upload/ext3sm.jpg)
![](http://forums.rennlist.com/upload/int1sm.jpg)
![](http://forums.rennlist.com/upload/int2sm.jpg)
![](http://forums.rennlist.com/upload/int3sm.jpg)
![](http://forums.rennlist.com/upload/int4sm.jpg)
![](http://forums.rennlist.com/upload/engine1sm.jpg)
![](http://forums.rennlist.com/upload/engine2sm.jpg)
![](http://forums.rennlist.com/upload/engine3sm.jpg)
![](http://forums.rennlist.com/upload/rearsuspsm.jpg)
![](http://forums.rennlist.com/upload/wheelsm.jpg)
Suspension:
Brakes:
-Non ABS Car
-928 Bias Valve
Engine:
-K26/8 Turbo
-MaxHP Chip
-3Bar FPR
-WebCam cam
-A/C Delete
-Reliaboost
-K&N Filter
Transaxle:
-80% Locking ZF LSD
Body:
-Front Tow Strap
-Rear Tie Downs
Interior:
-Air Bag Delete
![](http://forums.rennlist.com/upload/wingsm.jpg)
You list the car has an SCCA log book and you've raced from 03-08, but what group/sanctioning body do you race with that allows the mods you list? Can you run that stuff in West Coast ITE?
It ran ITE and PCA2. The OR/NWR SCCA run regional groups condensing the PCA classes. PCA2 contains PCA GT3. NASA does not run in the Northwest so the choices around here are ICSCC (Conference) or SCCA.
Now on ebay. Starting at 10,900 no reserve. Lots of car for the money.
http://cgi.ebay.com/ebaymotors/Porsc...spagenameZWDVW
I didn't even know you had a 951 Eric? So obviously you prefer the '68 as a racing platform.
Nice car and someone should pick up a bargain.
Relisted on ebay. Somebody is going to get a screaming deal!
http://cgi.ebay.com/ebaymotors/ws/eB...m=110288480714
