Starting on one side of the fuel rail the injector fits deep into the manifold, then each one after that sticks out a little further than the last. Is that normal or is the rail not sitting right?
Put a little automatic transmission fluid on the o-rings so they will slide into their ports without hangind up. I put the rail in place and make sure each injector is seated in their ports before tightening the bolts.
