belt squeal
Guys, I searched in the archives, but am unsure. I turned on the ac today and was met w/ a loud squealing noise that went away after awhile (w/ engine speed). The voltimeter dropped to 12v during this occurrence. The noise goes away w/ no AC. Is it an AC belt that I am looking at?
Wax On, Wax Off
yeah, I replaced mine recently, and the A/C works better... Anyway, if that doesn't work, I've heard that the A/C compressors on these cars tend to enjoy a good seize up.
My money's on the compressor locking up, if the AC is not working...
Happened to me, with the exact symptoms you described, plus the A/C was no longer chilling (you didn't say if the A/C still worked...)
If however the A/C still works, then the belt should be tightened or possibly replaced (they get slippy and glazed with age/use. -While you're at it, CHECK THE SIGHT GLASS!!! -If you see bubbles, bet it topped off before it does run low and seize-up completely.
Keith
Keith
AC is working fine today w/ no squeaks. I am assuming it's the belt. I'll have it in to the mechanic this weekend for boost gauge install and oil change, so I'll have him check. Thanks for the help.
