XP FS: Vitesse MAF, 72# inj 3bar FPR, 3.0L block, Crank, 2.7L head, DME KLR other
All prices below do not include shipping.
I have a Vitesse Maf, chipboard for either 24 or 28 pin DME, 72# injectors and 3bar FPR. Used less than 2k miles. I am going to try a Stand Alone DME so this is the only reason this is for sale.
Asking $1350 plus shipping
1 set of 86 951 offset phone dials 16 $500
1 set of 86 951 offset phone dials with brand new tires, wheels are not perfect. $750
A set of 18" cup II wheels, no center caps, Rears 18X10 ET 47 Fronts 18X8.5 ET 52 $450
4 H&R 32MM spacers with bolts, do not require use of longer studs $275 for all four or $150 for 2.
K26/6 turbo, no shaft play. $150
89S DME, no chip $300
89S KLR with chip $ 250
Standard 951 Front sway bar $100
Good used fuel pump, very clean. $75
New 951 Release bearing $175
2-951 Shimmed factory wastegate good condition $100 each
Front and rear Burgundy Script seats $1000 really nice.
951 Cross drilled crank $300
Turbo motor mount for oil feed $100
I do have a 3l block, with skirt and balance shafts it will need machine work, and I can get that done for an additional $400 to your specs. $1000
3.0L crank $1000
2.7 head 8V head $1000
951 Air box and snorkle, $75 good condition
951 Headers (stock) $200
951 Block, will need to be bored to 101mm $150
951 Crank, $150
If you need something that is not listed, let me know. I might have it. I need to get my garage cleaned out before my wife kills me.
3.0L crank $1000
951 Crank, $150
