Ok - Fuzion ZRi or Hankook Ventus RS2?
Got seat time in both? I wanna hear from you!
Fuzion's seem to get wonderful reviews end to end.
Hankooks appear to be the stickier tire (bigger blocks, lower UTGQ) but have less feedback overall.
Leaning towards the Fuzions - can anyone talk me over to the Hankooks?
Usage will be aggressive street with an occasional auto-x and HPDE usage when I don't mount up the RA1's.
ZRi's are worthless past 50% wear, and they have a lot more sidewall flex than I like.
Never drove with the Hankooks, but I have been in a car with hankooks (not those), and it was a very sticky tire.
LFA951 can talk you into the Hankooks. The Fuzions are great aggressive street tires especially in the rain, but I think the Hankooks beat them on the dry and the DE stuff you do. Since you already have a set of RA1's the Hankooks are closer to them. I run the Fuzions on 2 cars and love them but I bet a hard DE day would wear them out quick once hot. Personally I would just swap between the Fuzions and the RA1's depending on the intended use.
In September, it will be two years I have the Hankook RS2s and the rears are more worn out than the fronts. They are very quiet and never fall out of round, even after sitting for a week, they have solid sidewalls, good wet traction and great dry traction, even though treadwear is 200 or 8/32", they last long and the rubber compound does not deteriorate as quick as you would think. Extremely stable at high speeds (120-150mph) and inspire confidence when changing lanes quickly at 100mph+ and they have unparalelled cornering capabilities. For $400 for all four, you will not find a better tire, plus the sidewall is pretty!
They have the R2S as fifth out of eleven mostly due to wet grip. Keep in mind that some of the tires that rated higher may not be available in sizes to fit stock wheels
http://www.caranddriver.com/reviews/..._test/(page)/1
I was posting that C&D has them listed as fifth overall with the wet traction being what knocked it down the ranks. What I take from the article is that the dry grip is so close between the top tires that they use their wet grip as the largest KPI to set final place. I didn't convay this very well while trying to get a post out really quick while at work.
I have the R2S tires on my car and love them. While my use of the tires is mostly tame around town driving, I have pushed them on occasion and have been impressed. One thing I really like is that they're quiet even when being scrubbed. I find tire screech very annoying especially since it turns heads and draws attention. These tires have not exibited any screech while either being cornered hard or broken loose when boost kicks in.
My sizes are 225/50/16 and 245/45/16 on stock phonedials.
